Need some advice on new Arb truck
T.C
  • Replies 28
We have 4 tipper trucks, Landrover 130, 6 ton Iveco, 3.5 ton Iveco, 3.5 ton Isuzu. If I had to have one it would NOT be the landrover! Great when you need it, but expensive (the oldest but most costly to buy vehicle in our fleet) uncomfortable (we all went to the same job last week, there was a scramble not to be in the landrover) and way to small! We've had two transits in the past and they were also fine.
If you need 4wd and can afford a LR there isn't much else, if you can operate without it most of the 3.5 ton tipper trucks are much cheaper and do a better job.
If you occasionally need 4wd just get a 2wd tipper and standard cheap 4x4 (not LR)as most times if your off road you get away with chipping onsite anyhow.. It would probably cost less then a decent 130 and be much more versatile.
I am a LR fan my first car was a series 3, but just don't think they make sense unless they are needed.
