  • Replies 54
I agree, mapp gas.
One click, whoosh, done. Clean quick effective.
Or having traction engines in the family, a lump of oily greasy rag with a splash of diesel, on the end of the shovel, flick a match, turn shovel to drop the fireball, stoke away.
If you're in a milder part of the nation with Cordyline palms or Phormiums the dead leaf fronds are great. Good use for something which is generally a nuisance.
I use bundles of 4 or 5 tied together over newspaper, but a single one can be lit with a match and shredding a single frond would probably make it lightable by a spark.
I agree with the above, Cordyline leaves work well but they should be very dry. Pine cones are my favourite, obviously they should be dry and OPEN. If you dip them partially in wax that would be ideal. They burn for a surprisingly long time, I often notice them still burning away long after the kindling is gone and the logs are on.
