  • Replies 64
Always worth disconnecting the battery for a couple of minutes to see if that resets it.
Bear in mind that as above, if whatever fault brought it on in the first place is still there then it'll just come on again, and be sure you've the code for the radio as it might need reset.
Tried the battery thing, I think it's the ABS sensor! As it comes on from time to time while driving, but it's been doing this for a year or so lol! But started doing all time then the EM light came on!
I've got 3 scanners that will plug into that:biggrin: it's it's the abs light then it's either a broken wire or the abs module and there only about a £1000:thumbup:
Good luck
