What would be the best saw??
Chicken currie
Are you planning on milling the stick or is the whole lot going for firewood?
Either are pretty big saws, so they (395xp in-particular) dont leave much scope for work other than milling or felling & cross cutting big timber.
If your looking for something which will cope with felling & processing this for firewood but then can be used as a good utility saw I'd say a 560xp is a better bet.
Even with an 18inch bar you should be able to double cut the gob on that and bore out the heart wood before felling. a 20" bar will give you an extra 4inches whilst cross cutting.
