Recently bought a ms201 from eBay, worked fine for a few weeks then every time you start it there is a high pitched squeaking noise, does it more when cold, revving stops it
Anyone got any ideas as to what the problem is?
It may be the clutch needle bearing, the crank bearing, possibly the coil is touching the flywheel lightly. The clutch bearing is the most likely, does putting the chain brake on stop the noise!
