  • Replies 24
im after info on this saw before i go get 1,
cheers
johny
Lad I work with has one its a belting saw no issues so far and it gets used all the time
I've had 2 of these saws. It will cope with most demands short of felling large trees which it can do only longer. Can start to feel a bit heavy if your snedding out all day. Super reliable and I would get another one. No issues in 3 years, first one got flattened by mistake.
Hi mate has the 461 been out 3years now in uk time flys thanks what size did you run on yours thanks Jon
Open the hole up in the muffler and it goes even better, have 2 and both have been/are spot on. Ones got a 20" narrow kerf bar and chain on from Rob D, pretty nippy through the wood with that on. Doesn't load up the engine as much so cutting speeds quick! Nice saw IMO!
