  • Replies 48
Did you put the tpl on the truck? Was it hard to do?
Would be a lot less hassle to mount the chipper direct rather than bodge up a 3pl, has your tm got an auxiliary on the transfer box?
John,
Yes I've got aux on the transfer box. I'm not bothered, but interested. I'm planning to I put a tracked chipper in the back or tow a trailer.
the tp was mounted on a fixed 3point frame/sub frame which also had the body any crane on,this was the third wagon it had been on! the pto on the transfer+gear box is not up to running a chipper, fact. I fitted a pto from a fire engine giving direct drive then to a blower box to knock it down and turn it round. not sure I would do a beford now as they are getting long in the tooth and parts are harder to find
That sounds like a lot of Work! Where did you put the pto? And what's a blower box? Ta
