  • Replies 38
zing it
thats what i would recomend about £25 inc vat ish
instead of that £4.50 stuff you have
the better the line the more likely you will use it
also get a 8oz bag
I've been using a bit of Ash for the past 4 1/2 years, does me great
Jamie
I thought most of your tree access was with spikes Jamie:confused1::001_smile:
Yeah but every so often i have to p....p....p... eh.....deadwood a tree
I use my throwline with my fancy srt stuff (i'm remaking my footloop as a whoopie sling type footloop:001_cool: i'll give it a go and see if it works)
Jamie
I'd like to see that jamie, you going to put something like plastic tubing to hold the loop open?
Been meaning to make an order with you for ages, only my money seems to go elsewhere at the moment.
Jamie
did mine out of 9mm tennex and it,s spot on and so easy to change and shorten as a step up at the top
Mesterh, the angle cut is because it was an offcut from a job, can't do with paying for a bit of wood.. :001_smile:
Ahh right I thought it helped with the trajectory, Ive spent many hours wasted trying to work out the angle. :sad:
It can also be used as a tree inclination meter, if you know the angle of the cut then it wouldn't be difficult, with a degree in maths and science, to work out a givien inclination
Personally my own inclination is not to bother, get the job fired off and get home and put my feet up
