Hi,
I wouldn't buy a 261 or a 362 but would buy a 260 or a 361. However, Id like to think the 261 clutch bearing issue is sorted but consider it should be given a routine greasing.
So, that said, my choice would be a 461 running a 20" bar.
N
Needle bearing issue defo not sorted!!! Still disintegrating after 2 mins use from new. However if you change from a rim sprocket to a spur they Las a little bit longer with a good greasing
Edited by scottac1987
  • Replies 42
Hi logan thanks for thr info, the 3 main type's of trees are birch, pine, spruce, then the rubbish alder, pop, as for the saw I think a 261 with a 16 inch will be fine because when working in the forests if its to big I can leave it, I don't do domestic
As a forestry contractor, I have to fell whatever is marked up or clearfell, etc it seems you already have 2 small saws, surprised you'd go for another smallish 50cc when you could go for a 60cc that is happy cutting small sticks and in it's element with the mid sized trees?
When thinning, seems we end up felling the runts and the monsters. The 60cc copes with both.
As the title says , I am after a new saw and drawn to the 261or 362 I am a light user but I want one that will run an 18 inch bar at the moment I have ms 170and ms 250 it has to be stihl as dealer is around the corner, thanks for any input:001_smile:
Hi Andy better off with a 560xp andy there great best 60cc out there thanks Jon
