  • Replies 20
I'm sure the one on the front of the bobcat posted a couple of years ago was a lot faster
Yep thats the one I saw , it was quicker . He was picking a log off a stack , driving across the yard ( a short distance ) whilst the processor was working just in time for the first split wood to fall onto the pile . Continued over the pile till the stick was used up and went for another :001_smile:
It look like a bloody impressive bit of kit, but I can't help feeling that after watching it for a few minutes that it ought to be quicker....:001_huh:
Definitely needs to be quicker, I have them over here working in the forest and does seem painfully slow.
I did think it took it's time cutting it....a harvester bar flies through it normaly.
Modded stroke head. You are right, saw bar far too slow; should be much faster.
And another
or maybe a different vid of the first one
That one is a bit quicker than the original post as the bar cuts on either stroke .
I don't see the value in these at all. They're slow working, inefficient handling/transport, instead of one big log lying on ground you have lots of little ones... All mixed in with crap and lots of sawdust.
And I bet they're not cheap plus need an expensive base unit too.
If you were processing at roadside in forest and delivering direct to customer then they're marginally more efficient, load would still be full of crap and sawdust though.
