temporary roadway for crane in Suffolk. Any suggestions?
I have a job with a 50ton crane coming up. The crane needs to sit half on grass and half on a private tarmac driveway. I need approximately 30m for a straight drive in and out. Would be grateful if anyone has any suggestions. We can transport and lay the mats if this is an option anywhere.
Cheers
have the crane company not got boards? quinto charge us 50quid for all there ply wood sheets and plastic load spreading sheets, we turned up with the truck and trailer the loaded it with a forklift and away we went.
Quintos have said they cant provide anything only the feet pads. I am also still waiting for the quote from 3 weeks ago.
Have you spoke to crane company you are useing to find out what they need.
they have pretty much just left me to sort it. Said it will be a 50ton crane 3 meters wide and thats about it. They have mentioned trackway. I always thought it would be something crane companies could do in house.
Not sure what the pads are called but in the field up from my house they are tipping fertiliser and driving 8 wheelers across. Field on big plastic matts would be spot on.
We havent used them since they have just been taken over by a new owner, might be that or maybe because your using a different depot the kings lynn depot have the matting they replace the plywood sheeting very regular because it ends up like paper once driven over on soft ground
