  • Replies 125
Push it out with a screwdriver then plastic weld it and JBweld a plate on top for in future reinforcement. Make something that bolts into the screws holding the dogs on for a bit more cover.
Empty fuel tank and leave open in well ventilated area.
Clean and thoroughly dry repair area.
Form remaining plastic back to shape.
Carefully drill small holes, one each to encompass the ends of the crack to prevent continuance of crack forming.
Clear plastic swarf from inside & outside of repair area.
Using hot air gun, overfill repair by melting a suitably coloured Lego block into gap; smooth flat while warm or sand to finish when cold.
Edited by TGB
You can melt Lego in acetone to make repair paste but it is for ABS plastic so you need to know what the saw is made of.
[ame]
[/ame]
If its ABS you can dissolve in with Methyethyketone ( spelling) Or Osma drain cement .
How on earth did you come across that little gem of knowledge !!
Amazing the things folks know about.
Used to work in a tool room/dev shop and used it quite a lot .
So you effectively ..Plastic Weld .. once you melt it ?
