Worth checking the internal carb gauze filter under the cover with the single screw and the manufacturers name on it.
If it is full of sawdust, it will starve the saw of fuel when flat out but it may just be a partial seizure.
Worth checking the coil to flywheel gap although this usually stops the saw working when warm.
Check all is well with the plug!
Internal gauze filter? Having a look but not seeing it!ImageUploadedByArbtalk1414928872.350193.jpg.ba0297e44f468c15701448357f475a8b.jpg
  • Replies 55
That fuel line doesn't look great, you only need a tiny hole that sucks air in when the saw is under load and it will cause problems.
It would only be a few quid to change that.
Yep I was thinking that, will order one.
If you are still talking about the tank filter bin it and fit new. Easy things first.
Will get new one with fuel line.
