  • Replies 22
I think that the amount I take the rakers down (I use an angle grinder - it takes too long with a file), it would snag and stall too much if I didn't hold onto it! :laugh1:
Ha ha! :biggrin:
Ref the lady she could be making a come back soon - in fact may do some sort of poll or similar and then it will be down to the vote it being a democracy an all :biggrin:
Had my first on MS660 with one of the new 42" GB lo pro bars - new oregon 91R chain - revs stayed up but cutting was slow. Gave smooth results but I'm going to tweak the rakers down and see what that does.
:001_smile:
I started off with a 660 and 36" bar but that was to slow and knackering, then moved to an 880, the solid nose stihl supplied is no good for milling so bought a 42' sugi from Rob, nice bit of kit.
I've just had to buy a new 880 as the old one blew the spark plug out and although it can be repaired I needed a saw straight away. Once the old one is repaired my next investment will be a double ended bar off Rob using both 880's.
I keep the 660's with 26" bars for small logs or cutting up, that size bar makes a well balanced saw.
