I now and again run a 30 inch bar on my 046, it will do it, but if you wanted to regularly run that bar length and cut quickly you would be better with a bigger saw. It won't run a 36 inch bar unless you put in the high flow rate oil pump and then you would be better with a semi skip or full skip chain to reduce the load on the saw. A great saw :)
