Tyre sizing for ford ranger help
prolinep
So I have got a new ford ranger and the tyres in it arnt the greatest for mud to out it that way. Size currently are 265 x65 x17r
I want to put for bf Goodrich mud km2 on it but the closest sizes I have a choice to are either 265 x70 x 17r or a 245x70x17r
If I put the 265x70x17 on short of making it a tiny bit difference is speedo ( 30 will become 31) should I be alright with clearance? Anyone with a new ranger help me n this please ?
You will lose 2.5 mm of clearance wont you. Which should not be a problem.
And very very slightly gear the truck up like you said.
Is there a ford ranger forum to ask on?
I would check your warranty before you do though as they may try and fall back on "modifications" to get out of any repairs!(working transmission etc harder than intended)
I have put 265/70r17 on my new shape ranger, no problems with clearance on full lock, a very slight increase in ground clearance, and I reckon the speedo is more accurate as I always felt it read a bit faster than you where doing on the old tyres, with the new tyres checking using sat nav, and gps speedo on phone, its still reading a bit fast, but better than before. I can live with that.
On a side note, I have just had a new replacement tacho fitted and calibrated in my truck so used that as a bench mark to check the accuracy of the sat nav and gps speedo on phone.
