I got my wee chipper a couple of weeks ago. It's great.
There is one wee issue I would alter.
The discharge chute is very hard to tighten efficienty due to the knob being to close to the chute. This has lead to it flying off and a shower of chippings on a couple of occasions.
The solution is very simple. Two or three of these white plastic spacers on the bolt would shift the knob far enough to the side ( away from the metal) to be easily turned.
I'll pass your comments onwards to the relevant people. Thanks for posting.
What's yours called BTW?
Oh I better get my thinking cap on if you've to name them
had the same problem on my older style Greenmech GMR100 except the chute was secured with a large plastic tipped 'wingnut' which i simply reduced the protruding 'tips' by grinding 3mm off of each one.
