Tuning
Al Mondz
A very tough rule is one turn out from fully in on both screws but there are some exceptions.
If the saw has limit caps on the carb, the setting is different and with Stihls, generally on the side of the air box.
These settings are the starting point and whilst the H screw is generally pretty much on factory, I have found L screws to need + or - 1/4 turn on factory settings.
The H screw is the critical one and is always the screw furthest from the engine, lean it out too much and the saw will over-rev and will possibly seize.
Tuning your saw is not to be taken on lightly, leaning the mixture on the high jet can result in over reving and seizure, the carb should not really lose its settings, things like blocked air filter, blocked fuel filter, and or air leaks will alter the carburation, you should not alter carb settings to compensate for these issues, all max revs should be checked with a taco, not by ear, you need the Husqvarna model for us to give the max factory rpm.
Fully seated is wound all the way in (right), the screws are then turned anti-clockwise to richen (add more fuel) the mixture. The factory defaults can be found in the manual. You need a tachometer to fine tune the saw
Exactly, but just remember to only wind then in very gently until they just stop. Do not force them all the way in or needle and seat damage can result
