The diameter is no problem but why rings. Worse possible for chipping. How long are they.
Southern wood energy could do it but if short rings then it is a recipe for constant jamming. As you probably know chippers cut well across the grain but not with it.
WH Bonds Liskeard have two bandit beasts (one is for sale) this will not have a problem with rings,but I don't know about if it produces G30/50
  • Replies 34
Rings 8 - 12" long.
I would say a bit less for hardwood. Why chip it, surely would be more money in it to sell for firewood
Like I say, never make a good return if you manually handle timber and investing 35K in machinery, which will handle 800mm dia. arb. waste is definitely a non starter.
A sensible train of thought to many people of course.
Shredded chip is not good for biomass if that is your plan. bridges, jams augers etc.We have had a load chipped with the beast, never again. Very few biomass setups could cope.
Agreed- the Beast, absolute waste of time for biomass - good for conposting though.
Southern wood energy's chipper will handle the size, and the screen should do the rest - in theory.
I'll call them up.
I'll call them up.
Explain to Dan what you want to chip. I would think they might spend as much time clearing jams as producing chip. It will be very costly per ton then.
