Dead Copper Beech
philcaegrug
not sure if the carvers will want it as it wont last outside but there are other uses for it. if it's nice and straight it can be milled in to boards for furniture or joinery.
problem is that a girth of only 4-5' is only a 12-15" tree that has limited uses.
if you meant the diameter is 4-5' then it's worth milling, if it's only small then it will probably end up as firewood.
