Hi all, some advice needed. I have two customers wanting poplars removed due to the constant suckering from the root system through there lawns and driveways. I have explained that removal will probably make the issue worse. What is the best course of action to chemically kill the tree prior to removal to lessen the subsequent growth from the root system. Any thoughts and methods would be appreciated.:001_rolleyes:
We cut a deep ring around the stump and pored some stuff in ( cant remember what it was called now but really powerful ) and also brushed some on to the surface of the stump .
lots of round up on the stump and suckers that should help
As above. Must be applied on fresh cuts, for the Glyphosate herbicide to be transported into the root system, thus killing it.
Thanks for the replies guys. Carl where do you get the Eco plugs from? Was going to drill in to the butt and fill with chemical or salts and leave a bit for them to act. Cheers Carl
I would kill them in situ before felling. If you don't want a forest of root suckers, although it's seems to depend on what type of pop.
Easier said than done mind!
Last time we did on mature pops took four visits putting in Ecco plugs and still didn't have much effect.
Ended up drilling sloping holes and pouring in neat round up.
Needless to say made a big loss on the poisoning part of the job.
Amazing how difficult it can be to kill a healthy tree. Have wondered about using a tree injection system like arbor jet to introduce roundup next time but haven't had a job recently that requires it.
You can't alway compete on price but you can on quality
ive applied glyphosate to freshly cut black and white pops - a good dose was given and they suckered everywhere some coming up through tarmac.
I used to put a disclaimer with the quote to account for the possibility of such a scenario
Edited by Paul Cleaver
hit enter button by mistake
