Anyone mounted a 3pl crane to a chipper by fabricating a mounting bracket or similar? Got a bandit 90 and a kts crane and looking for ideas how to mount the two together?
Hi WAZ I no gray git john been using one in the past mate he tell you thanks Jon
Both 3pl, crane under warranty so can't really modify that, thinking of a bracket that mounts to the 3pl then the chipper and crane bolt to the mount. I'll try get pics but the crane is mounted to trailer at present
Some big box section that is welded up with some mounts on it. Chipper bolts to the frame frame bolts to the crane and the crane bolts to the linkage.
Hope you have a big tractor as it will be heavy.
The lad who built the Bandit 254 below lives in East Yorks, perhaps he would build it for you.
Sent from my iPad using Arbtalk
Yeah I saw that pic Steve on google, hard to see what's going on there, looks like a top link either side at the top but hard to see how it goes together at the bottom. Dean is the fella on here?
The 1 I used was a farmi and a botex 360tl that simply had a set of link arm ends welded into the crane A frame to hook up the chipper, longer pto and a very short top link also onto a bracket just below the slew point. The crane was welded by wilsons so didn't affect the warranty and the chipper was unmodified apart from a longer pto shaft.
