We have had a Jenson a530 10'' turn table for nearly 2 years now and we are having trouble with small brush and twigs getting caught between the outside of the rollers, therefore causing the two to have an inch or more gap, so they dont mesh.
So when you try to put smaller brush through the feed rollers havent got the purchase to pull it through. Or there is brush still wedged inbetween the top roller and the housing which doesnt want to go through.:thumbdown:
Confusing?
Does anybody else have this problem with Jenson?:mad1:
moan moan moan
1 gallon of petrol and 1 match will save you countless hours repairing it, Claim the insurance money and buy yourself a timberwolf!!!
Im not being funny mate, Ive just had really really bad times with jensons over the years!! :scared1:
Im sure people have had bad times with timberwolfs too though!
are the twigs getting stuck down the left and right rather than in between the rollers
or are they in the middleish
the twigs tend to get stuck on the left, where the top roller move up and down. it means we have to open it up and clear all the crap out where the u.j's are.
yeh ours does that too then
have your uj,s moved as well or has the roller shafts been moved a bit
we moved ours back left a bit and it was slightly better but usually find putting a bigger bit in clears it
hows your gearboxes lasting
i think everything else is ok. your right about putting bigger bits thru to clear it. that works a treat.
whats up with your gearbox???? uh oh
sadly ours started of as a friday afternoon machine
had 3 gearboxes
couple of uj and allsorts of other issues
but does not seem too bad at the moment
