I bought a Farma G2 grapple and made up a bracket to fit my machine
I hope you're gonna weld a brace in there before you paint it. Otherwise it's unlikely to last very long.
underneath the bottom box section weld on some pins about 3 inch long it lets your steer your poles without them kicking out when you steer
It's far from finished, needs a little bit of bracing, a tree pusher on the top and a proper heel at the bottom of the mounting plate before I paint it.
Having said that it's pretty strong as it is.
Sent using Arbtalk Mobile App
Vemac engineering cost £500 I'm well pleased
keep the pivots well greased as the cheaper end of the market the pins and bushes aren't usually the best quality
