What machine is it and what are the symptoms? Give us a clue and expert help me be available on line before you head to a local guru.
its a '97 entec ch25ph . with the 25hp kohler engine.
Now the first problem is that it does not have a chassis number which i didnt realise until after i purchased the machine so timberwolf cant be much help with specifics regarding my particular machine.
So the problem is that the rollers run fine if the the three pin plug on the anti stress control box (Old style grey box) is unplugged (obviously with no anti stress functionality).
If i connect the three pin plug the rollers wont move.
So my first thoughts are with regards to the trigger.
the one on the machine looks like it has taken a hammering in the past and the teeth are not very uniform. So i was going to try a new trigger as i am unsure of the tolerances.
I contacted timberwolf and they said that my machine should not have a twelve toothed trigger, which mine does.
So now that has opened up another can of worms. Do i persist down the route of a new trigger or has this anti stress system been adapted to fit my machine (looks original to me) there fore i am throwing good money after bad and i should just upgrade it to the later style anti stress system which will obviously cost a little bit more?
You should always aim to use the authorised dealer for the product.
First, they should have training in the maintenance of the product you own, but also they will be aware of any updates that can be applied to you machine in order to keep up with changes to legislation or to maximise performance.
Your dealer is Landpower in Somerset, Amanda Tribe on 01963 370654 or Holt JCB in Devon and Cornwall on 01208 78078.
