  • Replies 56
In short - as long as your depth gauge is accurately set to the tooth then it is acceptable to have 1- 1.5mm difference
When i did my saw refresher a few months ago. I was told off and marked down on the maintenance because my saws teeth were around 1-1.5mm difference. It had never been caliper sharpened either. Admittedly i've just caliper sharpened so ever tooth is 5.45mm +/- 0.05mm but i'd say that is OCD.
I can't comment on the assessor/trainer but the fact is that there is no actual tolerance set down by city and guilds . Did the saw cut ? Was the saw displaying any unacceptable levels of vibration ? As long as the saw produces saw dust / chip then it is classed as sharp .
I've seen plenty of saws produce dust...I wouldn't class them as sharp! :lol:
I would have thought a 1.5mm difference between left and right teeth would produce a curved cut.
As an assessor as long as something comes out of the back then it cuts which in assessing terms is acceptable
Seriously? Well, you know what they say. Those who can, do. Those who can't..teach :001_rolleyes:
Nope it's called starting somewhere , bearing in mind candidates have seen less than 40 actual hours on a saw ( including maintenance ) which I'm sure you will agree is not an overly huge amount of time to become proficient in all aspects let alone a pro when it comes to sharpening . Would you not agree ?
