Just wondering if you had used the blade yet and if you found it any good?
Thanks
as op below :confused1::laugh1:
It cuts well, and does what it says on the tin - lifts the cut material up. The only problem is the operator gets covered head to toe in grass cuttings! :laugh1:
:confused1:
Yeh works well but you get covered in cr@p
I use a full face clear visor anyway but you'd really need a chinguard too, and overalls/waterproofs
Don't know if anyone else uses one, but I saw them advertised online so thought I would give it a bash
Airecut – The revolutionary brushcutter blade for serious cutting
Got a 300mm one, £18 delivered from Mister Solutions.
Cheap enough but thanks for the heads up on the pebble dash. I think I will stick with my sthil blade even though it is more expensive.
  • 7 years later...
Being using this blade recently it works really well, you have to use it with the same motion, you use with a  scythe. The grass this year is denser than ever as its being exceptionally wet weather for this time of year.
Would work  even better i reckon if  the strimmer has some kind of grass cradle fitted.
Grain cradle - history, use, and how to make one - Scythe Supply
Edited by Stere
