MS260 mysterious hole in cylinder - advice appreciated! :-)
Bryapatch
Hi guys,
Hoping for some advice about a mysterious (to me) hole in the cylinder of my 260, near the spark plug. Hopefully the pictures work and you can see what i mean:
So bit of background - bought the saw recently off a guy who put new crank seals, pot and piston in and carb.
First it ran fine, then it would stall when i let the throttle off and then wouldn't restart. I thought this might mean it was running rich, so i reset the carb to manufacturers settings, and got it idling ok. Then it ran fine all day on quite a big job, lots of logging so was working hard.
It still runs fine but afterwards cleaning it i noticed this hole. The spark plug was white aswell, which i know suggests running lean?
Anyone have any light to shed on this? Would like to retune it if nescessary before i do another job as i dont want to damage it through running lean.
Thanks a lot for any help, much appreciated.
Cheers
Alex
  • Replies 27
myself would,nt worry about the casting hole etc but would set the saw a tad rich'er on the h screw so it fourstrokes a bit on the top end
Ah right, so that hole is just a flaw from when it was made? So nothing to worry about?
Cool thats what i thought i should do with the H screw, thanks.
I don't think its a flaw . Look at it . If its cast in there ( same finish as every were else ) then its meant to be there , If its got a shiny finish then some one has bored / drilled it them selves for what ever reason . Either way it wont affect the running of the saw . Its in a cooling fin and I suppose it could affect the cooling minutely but nothing to worry about .
