  • Replies 32
I looks really good colour aswel. I think I may have figured out what it was that knackered the saw. Think I put a bit of petrol in the tank then realised that it was petrol not 2 stroke then filled it up with mixed 2 stroke, instead of tipping the tank out and filling up fresh fuel. Very bad error on my part
Sent from my SM-N9005 using Arbtalk mobile app
Got a husky double can but didn't have it with me used 2 separate jerry cans labelled petrol and 2 stroke but pocked up the wrong one to start with
My 550xp began playing up last week. The chain turning slowly on idle which I identified as being a clutch spring failure. I purchased a set of three on eBay and now need to fit it. Can anybody please tell me do I need to remove the clutch to do this or can it be done in situ? It's a three shoe clutch.
Cheers
John
Cheers
John
The clutch has to be removed prior to swearing at the new springs as you try to fit them
Two tpes of clutch on the 550 one with two claw type springs, and one with three small springs, useing a pair of long nose external circlip pliers will aid you fitting both types, you will need to remove the clutch to fit the springs.
