Afternoon all, could any one advise me on how to estimate the weight of a popular trunk. It is approximately 10'6" in circumference and 32' in length, need to estimate for skip allowance on a quote, or could some one point me in the right direction for an equation that might help, much appreciated, mark.
Being from the continent, I have to convert everything to metric units before I can do any calculations (sorry).
* 10'6" circumference = 3.2m, giving a diameter of (3.2/pi) = 1.02 m.
* 32' height = 9.75 m
* Fresh poplar density = 600 kg/m3
An easy formula for calculating the volume of a cylinder is (height*diameter*diameter*0.78).
Total volume, assuming diameter of 1.02 through entire length = 8 m2
As it is likely that the circumference was measured at breast height, I would guess the actual volume to be about 30% less (which would assume a top diameter of 0.7 m) = 5.6 m3
In that case, the weight would be 5.6 * 600 kg = 3,360 kg.
Edited by morten
I found a calculator for you for computing weight of logs: Log Weight Calculator at WOODWEB (imperial)
It doesn't have Poplar, but you can use Aspen for similar density.
Input:
Species: Aspen, Quaking.
Small End Diameter: 28 inches (my best guess at 70% of large end diameter).
Large End Diameter: 40 inches (your 10'6" circumference divided by 3.14)
Length: 32 ft
Resulting estimated weight: 7979 lbs (which is 3620 kg).
The metrically inclined can use this calculator: Log Weight Calculator at WOODWEB (metric)
Input:
Length: 32 ft
good calculator.
pity they dont list the species as well as the common name. it's american so sycamore will be "platanus" not "acer".
I got 544kg from the bartlett app for iPads, or 1200 lbs.
32 feet at 12 inches dia. Yellow poplar.
Jomoco
The diameter is 40 inches, not 12 inches!
Oops, yellow poplar at a five foot dia for only 16 feet up weighs in at 12000 lbs or six tons,
So yeah could be real heavy pick with a crane.
Jomoco
So I run the yellow poplar app at 40 inches by 32 feet and still get 10,624 lbs or 5.25 tons.
That's a heavy log.
Thanks for the correction mate.
Jomoco
