  • Replies 493
Having a big heigh chipper and a low truck back you will find it blows chip and dust all over.
Sent from my GT-I9300 using Arbtalk mobile app
I have found if there is a slot cut out of the roof near the bulkhead it allows air to escape which reduces this, I hope 😨
Im talking more about over spray as the chute will be to the top of your truck.
You can tilt the bed up about 15-20 degrees before you start chipping. As long as none of the rear bed framework is in the way it reduces overspray significantly. Only problem is if you have a warning horn as it tips up.
Yes I know you can but not if you have much of a roof on.
