Any bright ideas on machines to cannibalise into a diy kindler,i cant justify buying one but would like to improve on the manual method.Apart from an old power hacksaw there must be other old machines with a similar motion or mechanism.
Hi,
i don't know about building a cutter, but last year i bought an old kindling machine, running off a 1 kw electric motor. It has a knife mechanism, which using chopped pallet wood was making 15 bags an hour.(pallet off cuts from a local pallet maker cost me about £10 a cube). It's now sitting in the shed as i've found Genset Steve on here does nets at a very reasonable rate and i can just concentrate on the logs. Thats a free ad Steve!:thumbup:
made one last year but took ages to build. its basically a hydraulic ram pressing 15inch blocks through a fancy grid. its prob easier to make them on a log splitter
When you look at videos on the tube, a v shape cutter on a horizontal splitter, with a tray both sides to shuffle the wood along seems to work well, you could angle the out tray down to load bags
If you build any thing put some pics up:thumbup:
Hi,
Thanks :thumbup: hope things are going well. We are going to stock 1000's of bags through the summer to get through next winter as its going to be cold. We normally put prices up end of summer unless price of wood crashes then it wont go up at all. If you have the space to store get stocked up now the wood is new clean fresh and 14% moisture. Like this
Edited by gensetsteve
spelling
Vintage engine collector showed me one he'd bought
Was basically vertical length girder
There was vertical slide with knfe on bottom
Then eccentric pushing slide up and down, mounted above blade
Belt droven off a lister
Blade cleared bottom by about five inches ( hand width)
Idea was you held piece of wood under blade and moved it to produce kindle
Went at about 1000000 rpm ( ie far to fast)
I had visions of it snatching on a knot
Pulling timber out of your hand
And then using timber to pound your hand to mush
Very scary, but then I'm chicken
  • 3 weeks later...
its a honey comb grid- theoretically brilliant.... and it dosnt work:laugh1:
