Hello all you guys in suffolk area. When i fell some of my trees i need to give a little help with the tractor. I was wondering what you do with your ropes if they fail testing do you throw them away or not? I usually use steel cable but it would be easy to take up rope:001_smile:
depends on the size off tree if its just a twggy type 13mm ex climing rope any big stuff steel cable with the tractor on it & somtimes a snatch block.
Are you from the suffolk area?? NO. :001_tongue:
Surely you would have to assess who, or what would be at risk if the rope snapped whilst trying to pull over the tree. Most ropes that fail inspection only get the bit that is knackered cut off and the rest is fine. I have about 4 eyeless ex-climbing lines that dont coresspond with my v.t set-up so are redundant but look good hanging on my workshop wall.
frank if i thouhgt there was a risk off the rope snapping i would either double rope it or i,d climb the tree & reduce some back wieght off it & having felled a lot a large harwoods i,am well placed to judge what will fell & what wont fell :001_cool:
...and what do you know Johnny, Franks had loads of hair dressing experience and knows exactly how to do a quiff .. you shouldn't bring him down like that..
sorry dean i wont do it again it wasnt ment in an unpleasent way sir onest :001_tongue:
Now now calm down, i was just seeing if anyone had any rope to give away. I thought i would rather take rope up a ladder :001_smile:
take a small pully & rope up tree & get groundei to pull cable via pully & rope :001_cool:
I resent that totally. You have been well out of order. I cant believe you dare say things like that. I HAVE NEVER HAD A QUIFF.:001_tongue:
i got given a whole drum of ex BT winch rope this weekend (not your normal blue stuff) guy said approx 5 ton , how much do you need im in cambridge if you want to collect
