converting ms240 from .325 to 3/8?
shillo
Yes you can do it, but I would only try it if you are running a very short bar and cutting very small diameter material with it. The bigger the chain, the bigger the 'bite' it takes. If the chain is too long with too big a bite per tooth then it bogs down.
Alec
edit: new post has appeared indicating lo-pro. Yes, this will work nicely but it's tricky to find the right bar. Rob D knows which one it is but I don't!
Edited by agg221
