A few years ago I heard a tale that a good thing was to smear vasaline on fresh cambium damage.
I decided to carry out an experiment.
Two identical areas of fresh squirrel damage on hornbeam, left side left as is, right side smeared with a thick layer of vasaline and left for two years.
Vasaline has not been completely wiped off but you can still see the results, left side has very thick new growth and has nearly healed completely. Right side shows very little growth and new growth has lots of areas where it shows no new growth at all
  • Replies 20
Interesting Dean
I wonder if the parenchyma cells that go on to create callus tissue are inhibited by the Vaseline. Possibly by a reduced access to air and light?
Looks like a very vigorous tree.
Does it have a full canopy?
At the moment it is an understorey tree within a silver birch woodland, nice full crown.
sorry Gaz missed your post, yes its hornbeam, for some reason the squirrels are decimating them, they are leaving all the other trees but stripping the hornbeams ??
Edited by Dean Lofthouse
Interesting Dean
I don't really think wounds need air and light to callous. Everything I graft gets wrapped in a rubber band and then waxed over.No air or light gets to them and they callous very quickly and strongly.
Good to experiment, and follow up!
"left side has very thick new growth and has nearly healed completely. Right side shows very little growth and new growth has lots of areas where it shows no new growth at all"
Pretty hard to tell from here, under all that goop.
If the right side is nearly the same, the squirrels left a lot of parenchyma outside of the wood. If at that time drying was less of a concern, then sealing the area probably inhibited more than it helped.
If the wood was scraped bare by rodent teeth, I'm guessing that sealing may have done more good.
This is the invasive gray squirrel? I'm sorry it got loose over there--wasn't me!
