Entry level circular sawmill
Robert Raven
£7000 very expensive for a 2.4m cut. i would go for an old rack mill, cheap as chips and last for years
I agree - a racksaw would give you more for a lot less. Either that or a big old Stenner or equivalent vertical bandsaw which will take a thinner kerf and allow a wider cut, which is handy if you want to re-saw wide boards, like when you suddenly find that your stack of nicely seasoned 2" needs to be 1".
Alec
problem Ive had trying to resaw air dried timber alec,is that its obviously dried with some movement,and when put back on the mill its never going to cut them accuratetly again,unless I plane one side flat first,then I lose the thickness! mainly oak to be fair,the yew etc works fine,
I know what you mean but I've done it slightly differently. I am not the expert in this but I bought a load of 3" elm in 15" average width that had been seasoning since the 1970s and I needed it at 3/4" finished size. I took it to someone who is very good at this and we ran all of it through a big vertical bandsaw, against the fence but the top of the board was a long way above it. The saw has no infeed or outfeed rollers, so it's a person on each end of the board. This made it almost freehand splitting by eye, but the wide band kept it true and we didn't lose a single board. Obviously you can't take the cup out (although you can deal with a bit of wind) but it did work surprisingly well - the inner board was flat both sides, the outer boards flat one side to use as a reference to plane the other side from.
Alec
as long as it works,,cool! there is an old bloke up the road from me with a pitsaw/stenner he used to cut all my cedar that way,before I got a mizer, his place has to be seen to be believed,30ft high with off cuts and lives in a wooden shack,right in the middle of it all, man after my own heart.
Pics pls
