  • Replies 44
I've got the oxdale se400, had for a couple of years now. for what it is,no real complaints.
It had to have a new oil tank fitted as one of the weld seams split but done on warranty,
It lacks a bit of grunt for dealing with real knotty pieces or tough pieces of dead elm etc.
counting the days so I can get a tractor then get a good PTO jobbie.
I've got early oxdale
Ok until you get knarly twisted then can be bit of struggle
Bottom plate/table could usefully be bigger.....And if could be arsed would get some weld on it to make it a bit less slippy
Splitter head could be better designed, would be better if point was bit farther out and blade extended a bit further back - sometimes smaller logs slip behind blade
Ok for own use, probably not for commercial production
my good friend sean has a 27 ton one from rock machinery i think it was £12/1400 i,ve used it a few times its a petrol version by the way uses about a gall a day all depends how hard you work it etc as i,am just a plodder and dont punish machinery anyway he,s had it a couple years now no problems at all i also think rock have a website too and have new models coming out all the time check them out
R5log I made an involuntary sound when I saw that pic:blushing:
Now that's a splitter:thumbup1:
I've for a vertical 9 ton petrol from Fuelwood, can't fault it in any way.:001_smile:
As above 9 ton from fuelwood or infamous A11 from Balfor / Riko. Thor is good gear as is Posch. Budget and tonnage required tho ???
24 ft long in total!
We were at a show next wallenstein and used the WX900 to split down the big cord before chopping it up and it was a great bit of kit.
We are looking at getting a Screw Thread Splitter soon to go on the PTO
