This is the exhaust outlet of my 880.
Will fitting a second outlet (thereby doubling the area) provide any advantage ?
Drill some holes in the inner tubing ??
It should result in more power but make sure you richen the carb up and then adjust so the fourstroking disappears when hard in the cut.
Hi Steve what about chiped 560 then mate thanks jon
Hi Steve your pulling my leg mate yes mate that's it mate thanks steve thanks Jon
I think that will be big no on that one, I don't believe that anything is reprogramable by the end user on this saw - it does what the manufacturers intended it to!
