Footlocking!!!!
The Tree Hunter
Anyone got any tips or advice for footlocking??? i've been asked to be part of the climbing team for college for the comp in may at merrist wood, we've not done any footlocking and although i know the principles, am wondering if you have any tips that make it easier..........also do you have to wear chainsaw boots or can you do it in walking boots???
I first got to learn footlocking without knots or harness, ie just put a rope up and do two or three footlocks up a few feet and come back down.
Do this until you have got it spot on then introduce the harness and whatever friction hitch you decide to use.
You find you spend too much time thinking anf faffing about with knots rather than learning the actual footlock and building the muscles you need to do it, you need to train the muscles and yourself first
good advice by dean there.
whatever friction hitch you use should be out of reach when you are footlocking....and should be ignore. your hands sliding up the rope should advance the hitch as if it wasnt there. if you have it set wrong and have to physically push it up you're wasting valuable energy
