Blocking, chunking, undermining the COG
COB = centre of balance in this instance.
I have seen so many guys making a meal out of chunking down over the years.
Heres some video and pointers which might help, I hope.
Watch in HD. Thanks
[ame=http://www.youtube.com/watch?v=4ga2cxCg0B0]Blocking, undermining COB - YouTube[/ame]
  • Replies 26
"..or if your cuts are just s in general, this technique is probably not for you."
haha :D
Very good instructional video. Nice one.
Edited by Stephen Blair
Xxx
Good job Reg, It's a great tool to have in the box indeed.
I try & place the back-cut level with the front cut - less vertical wood to split in the hinge (you can retain a bigger hinge ), less chance of over cutting & having your saw taken with the piece & easier to see & judge such a fine hinge - hope that all makes sense
I've always just done break cuts as I find putting gobs in takes a lot longer and when it goes over it sends it further away from the base of the stem, but it does limit me to length of chunks I'm knocking off.
I'll give that a go next pine I'm dismantling:thumbup1:
