Knots used in treework
Sciadopitys
I have been taught that a reef knot should not be relied upon as it comes undone very easily indeed. Woodpicker is taking the piss incase anyone decides to try and make prussik loops with a reef (square) knot! :001_rolleyes:
on the contairy my boy when you use the reef knot you have 3" off play which you tape down 2" & leave 1" visable so to check any movement i used them for 15yrs 1 never came free & i never fell from a tree :tongue_smilie:
  • Replies 34
is the quick hitch not also called a slipery sheet bend
and i think the best knot for rope to rope is a sheet bend and that its easier to tie
tie a marine spike (normal knot used for saws etc) put the rope through the loop and pull the loop back out (as you would to undo normally) this then pulls the lowering rope through with it and results in a sheet bend
and its very easy and quick to tie
