Next order of Sugihara bars - what do you want?
hello ed have you got the straight 8mm bar studs on your makita or has it got the 12mm shanks at the base of the mounting studs
cheers andrew:thumbup:
It's a 2000 model I think if that helps, I will have a look at it tommorow,
Sent using Arbtalk Mobile App
  • Replies 184
56" bar for Stihl 088 please! Don't argue, just make it happen!
try cannon super bars they do a 5ft bar ive got one on an 88 its heavy and un-wealdy but don't come across many you cant cut right through
Rob
left a message with your young lady operative for 4 of the 1st order of bars that I had from you.
regards
Jeremy
Thanks Jeremy got that, sent it you'll have today - I thought it was for x3! You've only been charged for x3 anyways!
Cannon bars are great but found the longer ones are quite floppy like the GB ones... the longer Sugihara bars are def stiffer but don't go above 46" in length.
:001_smile:
Hello mate, have these on the dcs9010 ImageUploadedByArbtalk1394556599.845723.jpg.119e58c1abc5d8f9ea0c2a7a5ca18d50.jpg
They look like the D009 mounting studs - do you know anyone with a large 70cc + Husky - all the bars for these should fit on your makita (as a double check).
:001_smile:
:001_smile:
So my 576xp bars should fit it? Cheers rob
Hi Rob, When will you be getting the next order of Sugihara bars in? I'm after 16" & 18" to fit Stihl running 3/8".
What model saw if this for?
I'm pretty sure I already have these in laminated and pro solid versions...
Guide bars
:001_smile:
