Next order of Sugihara bars - what do you want?
That all seems pretty fair Steve - hope it comes through smoothly.
Wouldn't life be a lot simpler if Stihl moved to .058 or Husky moved to .063??
:biggrin:
Yes. But that'd be too simple wouldn't it?!
  • Replies 184
I think you should be sorted now? Is this Paddy from Finland?
You had a rough deal there as you ordered just as we ran out of Alaskans and then the next shipment was 6 weeks late but hopefully you're planking now!
:001_smile:
Alright mr rob, did u ever find a nice sugi 36" bar to fit the big Makita? (Dcs9010)
Sent using Arbtalk Mobile App
Is the DCS9010 an D009 mount? In the oregon manual it seems to say it is... and it isn't!
It has it listed as D033 and D009...
I'll stick a thread up on it...
:001_smile:
Hi Ed - sorry it seems the Makita DCS9010 is an D009 mount!
So if you put in Husky 395XP here Guide bars
These bars will all fit (and same for chains).
Put in 'arbtalk' as the voucher code when you check out for a good throw in!
:001_smile:
Ed as a double check - try one of your bars for the 576 on the Makita and see if it fits - this will be a D009 (idea courtesy of treebeard! :biggrin:)
Will do thanks rob, if it fits I will order at the end of the month, thanks buddy
hello ed have you got the straight 8mm bar studs on your makita or has it got the 12mm shanks at the base of the mounting studs
cheers andrew:thumbup:
