If your going to Kilworth we are only couple of miles away if you want to see our set up
Sent using Arbtalk Mobile App
  • Replies 32
the only problem I've found with a winch on the back of the smaller alpines is even with the plate down, a large log,or hung tree, can pull the whole set up back, and leave your intended "victim" in place
Treehugger I have a 1.5m INO flail on y blades on my 50hp Alpine, its a cracking combination and deals with some pretty thick stuff on steep ground, dont think id go much bigger mind as it takes some running & anything heavier might upset the balance. Speak to Jim at Riko, he gives good advice!! Cdo.
