broken on/off switch, advice needed on repair
david wood
Should only need a screw driver
Part no 503 71 82-01
Gardenhirespares.co.uk sell them @ £11.75 +VAT
Just be carefull ordering genuine parts from them as they do not hold them instock or thou it may say in stock had this problem 2 months ago when I need a part asap.
Most of these switches have fascia type retainers - these are two sprung plastic lugs either side of the switch that constrict when pushed in to the apperture and spring open once through the hole thus retaining the switch.
You normally get them out by pushing in one of the lugs and prising the same side of the switch out of its hole - pushing on the back of the switch normally does it.
Hoping dealer is around tommorow or its order off eBay and be at mercy of post, least its broken in on position. Good to know how switches locate so I don't kill new one. First ever broken switch for me.
Just choke it to stop it . Used saws for months with faulty switch .....
