Bt45 wood drill
Dave Alviti
Anyone used one of these? https://www.frjonesandson.co.uk/products-page/machines/augers-drills1/stihl-bt45-wood-drill/
Got a strange job in the new year where I need to drill through 25" stumps and need to know if this is man enough?
I've used them for ecoplugs, the drill will manage it if you keep the bit clear. The chucks supplied won't grip a 13mm round bit if the going gets tough, find a bit with a hex shank.
Thanks for that, what's the longest bit you've used in one? As I need to drill the full width of the stump
Ecoplug bits are 13mm but they have a depth limiter of 30mm. Bradpoints don't pull in like ordinary augers with a thread at the tip and this is preferable to stop jamming.
Previously I used longer bits on an atom drill attachment for a husqvarne 268 in the days I did cable bracing. I feel sure the BT45 would manage the same.
How far from me are you?
In west London at the moment, but the job I need it for is in Shropshire
I've used it for drilling and placing Eco plugs. I thought it was a cracking drill, the company who owned it who I was subbing in for welded a big washer on the drill bit as a stopper so you couldn't drill to far which I thought was a good idea
