Chain sharpening
Sciadopitys
  • Replies 61
i think a machine is a waste off money to sharpen a 066 would only take a few minutes
If you had a 96 drive link chain which required 10 strokes to get a good edge, allowing 1 second per stroke and 3 seconds between changing teeth with no rest whatsoever =
96 DL x 10 seconds / strokes each = 960 seconds
96 x 3 second between teeth = 288 seconds
total = 1248 seconds
or 20,8 minutes
To do a 30 inch chain with ten strokes in a few minutes you would have to be the six million dollar man.
Now say you were ringing up a huge stem and hit a nail three times, thats well over an hours sharpening or wasted time. So it isn't a case of not having the time or energy, it's a case of giving the customer value for money, they don't want to see you sat there for over an hour sharpening saws
or 20,8 minutes
and thats before you've picked up a flat file.....
10 strokes per tooth!!!, you'd have to be a bit gormless to do that much damage, I reckon on average your talking 3 strokes per tooth and only a second between each tooth.
Let me know where you buy your files from Dave, they must be good to remove so much material in one stroke :001_smile:
Nail damage is nearly always ten strokes because the chromium plate peens over and the first few strokes just slide over it.
If you can do 96 teeth without a break of even a second you are doing well mate, 3 stroke per tooth is touching up
any more than 5 strokes its time to make a brew & give the chain a proper dressing up flat file & all
