so my 25hp engine is going to be cool it a v twin
It will be better than mine if it is a genuine 25hp but still 5hp short for the minimum I would say .
  • Replies 74
I mite have f**ked up I see the two in the photos the engine are the other way round to my one .I.E under the screw .my engine will be behind the screw shaft will be facing the same way as the screw so I think it will not screw in.
or can the guy in Poland cut a screw the other way round?
They can cut R/H or L/H helix . Be sure to get it correct though or you will have f**ked up !
cool WHEN it,s dry I will go and work it out
it need to cut into the wood so if the engine turns clockwise it a right hand helix?
You need to specify which direction you are looking . Usually looking on the business end of the crank shaft ( where you would mount your gear wheel or pully ) .
Stand facing the machine where you would be operating it from ( facing the pointy end of the cone ) Imagine the cone is a bolt or stud . ( standard R/H thread ) . Spin a nut half way along the bolt . Grip the nut and if the rotation you have pulls the nut away from you then you need a R/H helix . If with the rotation you have the nut is pushed back toward you then you will need a L/H helix . The log being the nut and the cone being the stud you need the log pulled onto the cone , away from you . Make sense ? hope so .....
Your all mad using a screw splitter lol or just dead ard just watch it does,nt bite back not funny there scarey things gives me the hebeejebees watching someone else use one stuff that i bought i used got bit a few times i sold lol
