I am looking at making a screw type splitter (from ebay)
I have a belt drive saw bench 25hp
and want to put it on the back of it
do you think I will have the power to run both at the same time
the saw will cut at half power with ease
  • Replies 74
You will need at least 25hp dedicated to the screw splitter . Anything less and it will stall on the gnarly knotty stuff . Provide it with enough torque and it will be faster than a normal hydraulic splitter . Don't give it enough torque and you will loose time cutting stuck lumps off . Also this damages the bearings as it tends to force the cone upwards when a piece gets stuck . You need BIG torque and relatively slow revs .
The revs would be my biggest concern - I have a hycrack that runs directly off a tractor PTO and 540rpm is plenty fast enough. I'm not sure what a circular saw runs at but I'd imagine it is a lot faster than that. If you can gear it down, subsequently increasing torque then I think it might work.
  • 1 month later...
I am going to gear it down to about 3to1 about 600rpm
has any one use the kit on ebay from Poland?
Yep . I got a cone from Poland and its good . No problems :001_smile:
