NPTC Assessor North East required
The old CS33 has gone and has not been replaced.
Instead, the upper size limit has been removed from the equivalent of the old CS32 unit.
It is now called " Level 3 Award in Felling and Processing Trees Over 380mm" which is a real catchy title 'eh?
Link to the assessment schedule is here...
http://www.nptc.org.uk/assets/documents/10503ffbbfca45a0ab2c6772d32669f3.pdf
It is worth noting that this is now and integrated training and assessment qualification, which means you are assessed as an ongoing process throughout the training rather than having a seperate 'on the spot' assessment.
It is entirely your choice if you go through Lantra or NPTC, they are identical and interchangeable qualifications now.
